Activity › Forums › Panasonic Cameras › Making dubs from 1400 deck to HVX200
Posted by Matjik on July 3, 2007 at 3:06 pmIs there a way to dub an DVCProHD tape to DV via firewire to tape on the HVX. I set the 1400 up with the correct menu settings for 720p to DV according to their chart (and it works great with FCP), but the HVX is not receiving a signal. Is there something in the HVX I need to adjust?
Matjik replied 19 years, 2 months ago 2 Members · 7 Replies -
Barry Green
July 3, 2007 at 9:59 pmMake sure the HVX is in “tape” mode, and in VCR mode…
Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db) -
Barry Green
July 4, 2007 at 9:47 pmAre you sending it DV data? If the deck is outputting DV, and the camera’s receiving DV, it should definitely show up on the LCD. Try a different firewire cable maybe?
Matjik
July 5, 2007 at 3:19 amDefinitely sending a dv signal because when I connect it to my desktop I can capture dv in fcp using the dv input preset.
Barry Green
July 5, 2007 at 3:42 pmDo you know for a fact that the firewire port on the HVX200 works? That it didn’t get “blown out” by hot-plugging into a six-pin firewire port on the computer?
I’m not sure what to tell you; firewire input definitely works on the HVX200, in all modes. You can firewire HD to it, or DV50, or DV. If your deck is configured to export DV, and the camera tape/p2 switch is set to “tape” mode, and the mode button is set to VCR, then it should be working.
Matjik
July 5, 2007 at 7:43 pmI know that it works because I just used it to lay something to DV tape from FCP. If I plugged another DV unit (like the consumer DV deck from panasonic) to the 1400 should it work? Because I’ve tried it with no luck. So it seems to be something with the 1400, but like I said it works with FCP when trying to capture DV from an HD tape.
