Activity Forums Adobe After Effects Expressions making different images appear using audio amplitude…
  • making different images appear using audio amplitude…
    Posted by Fernando Lopez on March 2, 2008 at 9:23 pm
    I saw a reply to a post that contained this expression:
    temp = thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”);
    value + [0,15]*temp/5;
    You would add the expression to a layer, after doing the “convert audio to keyframes” under the keyframe assistant.
    Instead of making an image move 15 pixels down when the audio level is 5, I want a different image coming up when the audio levels are 15. Then a different one at 8, then a different one at 0.
    I need help on this, please. Thanks guys!
    Dan Ebberts replied 18 years, 6 months ago 2 Members · 2 Replies
  • Fernando Lopez
    March 2, 2008 at 9:42 pm
    whoops!! guys, nvm! I found a solution. =)
    Thanks anyway!
  • Dan Ebberts
    You could apply this opacity expression to the top layer:
    if (temp > 15) 100 else 0;
    Modify it like this for the next layer down:
    if (temp > 8) 100 else 0;
    The bottom layer wouldn’t need an expression.
    Dan
