Activity Forums DaVinci Resolve Making cut adjustments.
  • Making cut adjustments.
    Posted by John Whitcomb on February 7, 2011 at 1:24 pm
    Scene Detector missed some cuts.
    Is the best way to make these cuts in the conform room on the mater timeline?
    Each cut I make takes exactly 1.5 minutes to complete. 50 missing cuts.. long time waiting.
    Should I fix it in scene detector and re-split? Will it retain my grades?
    Although now that I’ve started already making cuts in the master timeline using split.. I would loose those cuts when i reimport the scene detector split?
    It’s just painfully hard to sit and watch the wheel spin after each cut… :\
    Rohit Gupta replied 15 years, 7 months ago 2 Members · 1 Reply
  • Rohit Gupta
    February 7, 2011 at 3:03 pm
    You can create a new project with the scene detection and colortrace your changes. It will use the source timecode in the clips to copy over the grades to the new project.
    Could you send your project exported out to our helpdesk at davincihelp (at) blackmagic-design.com?
