Activity Forums Apple Final Cut Pro Legacy Making custom resolution MPEG2 streams?
  • Making custom resolution MPEG2 streams?
    Posted by Navarro Parker on September 3, 2009 at 6:39 pm
    Wasn’t sure where to post this as there isn’t a Compression forum. Please let me know if I should move it.
    A client has requested a 30fps 1280×1024 MPEG-2 stream for playback on a kiosk system. Yes, I know… weird, right? They are using some funky turnkey playback system that has to have MPEG-2.
    So it is possible to make an MPEG-2 with this non-broadcast resolution and frame rate? Every setting in Compressor 3.5 limits me to broadcast resolutions & ratios (480/720/1080 4:3/16:9) and frame rates (29.97).
    I’ve some had luck using VLC, but it’s limited to 3Mbit/sec (which looks pretty crummy at that resolution).
    So is there an easy way to force VLC to use a higher bitrate? (no CLI, please!) Or convince Compressor not to use broadcast standards?
    Chris Poisson replied 17 years ago 2 Members · 1 Reply
  • Chris Poisson
    September 3, 2009 at 7:21 pm
    Hey Navarro,
    In the crop pannel you should be able to make it any size you want.
    Otherwise, this is really easy in Episode Pro.
    Have as good a day as you can.
