Activity Forums Adobe Premiere Pro making clips
  • making clips
    Posted by Gary Linzer on May 28, 2013 at 4:28 pm
    I have made a rough cut of a multicam sequence which is approximately 20 minutes long. The sequence is now cut into about 30-40 clips. Is there a way to mark or name each clip so that I can know what each individual clips content is. I need to now move the individual clips around and reorder them to make the final sequence but it is somewhat difficult to remember what is on each clip. If there was a way to now rename each clip or mark them in such a way that I’d be able to see what each clip was it would make it much easier. Any advice?
    Gary Linzer replied 13 years, 3 months ago 2 Members · 3 Replies
  • Kris Merkel
    May 28, 2013 at 4:40 pm
    Yes, right clip on the clip and select rename from the pull down menu
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
  • Gary Linzer
    May 28, 2013 at 6:47 pm
    Thanks, That’s a big help. one other question. Can you put marker comments on a multicam clip?
  • Gary Linzer
    May 28, 2013 at 7:55 pm
    Also can you rename multiple clips at the same time giving them the same name. I’m asking these questions because I’m not sure how to keep all my clips sorted so I can change their order to make my final sequence. If I could put all my cut up clips in a bin with their new names then I could bring them to a new timeline in the order I needed, but to move them around in the timelime when I have 30-40 or more clips gets a little confusing and cumbersome. the footage that I’m cutting is from and interview with about a dozen people who talk back and forth so I need to move clips around quite a bit even after I’ve done a multicam edit of the four cameras that I used. Hope I explained my problem. Any suggestions would help.
