Activity Forums Apple Final Cut Pro Legacy Making best quality DVD from FCP using Compressor
  • Making best quality DVD from FCP using Compressor
    Posted by Rajarshi Basu on August 20, 2008 at 9:31 am
    I tried the DVD preset from Compressor, but the QT file was created without audio ?
    Do I have to separately render out a .wav file and then sync it in DVD Studio Pro ?
    Please suggest…
    Raj
    Thompson Coles replied 18 years, 1 month ago 3 Members · 2 Replies
  • Rafael Amador
    August 20, 2008 at 10:23 am
    You should be able to bring the .wav to the STP time line because WAV is a PCM format.
    If you hav problems just export your .wav as .aiff in QT.
    rafael
    http://www.nagavideo.com
  • Thompson Coles
    August 20, 2008 at 3:03 pm
    Compressor will create two files when you use the DVD preset settings. one is the video the other is audio. you should import both files into DVD studio Pro or your authoring program and drag them both into a timeline. This will create a video track that can be used by the program. I’ve seen people use a single MOV file that has both video and audio to create the timeline. this always seems to create longer processing times because the authoring program re-compresses the file.
    Thompson
