Activity Forums Avid Media Composer Making audio tool more responsive
  • Making audio tool more responsive
    Posted by Lucas Merino on July 10, 2006 at 3:50 pm
    Are there any specific settings I can change to make the audio meters more responsive. They bounce around so chunky-like I cannot get a good reading.
    thanks
    Lucas Merino replied 20 years, 2 months ago 2 Members · 2 Replies
  • Dan O’brien
    July 11, 2006 at 7:24 pm
    Assuming you have sufficient comp speed and all that…
    try rendering any effects you have first for seqs with multiple layers. Or just monitor the bottom video track (or no video track at all) if you’re only working on audio. Turning off your video monitor button in the timeline always speeds everything up, and it’s a great way to work on audio-only stuff.
    Other than that, close any unneccessary bins, make sure there’s not a lot of overlapping windows, that kind of thing…
    Good luck
  • Lucas Merino
    July 12, 2006 at 2:33 pm
    I turned off the video track and that worked well. Im running on a certified HP xw8200… unfortunately it’s not as responsive as hoped.
