Activity › Forums › Adobe Premiere Pro › Making audio sound worse within premiere
  • Making audio sound worse within premiere
    Posted by Beatcow on July 23, 2007 at 5:20 am
    Hello, I am currently working on a project that involves making footage seem rather old(1970’s). I filmed everything on a DV cam, and so the quality is too good. I got the visual look modified, but I haven’t been able to get my audio tracks to have that signature 1970’s sorta washed out and a bit scratchy effect.Is this possible from within premiere? If so, any suggestions on how I can accomplish such an effect.
    Beatcow replied 19 years, 1 month ago 3 Members · 3 Replies
  • Steven L. gotz
    July 23, 2007 at 9:12 pm
    It just so happens that I had to do this the other day.
    Apply a High Pass filter and reduce it to about 800 or so, then apply the Low Pass filter and run it up to over 12000. That should get you started.
    Only you can determine exactly what sounds right.
    Steven
    https://www.stevengotz.com
  • Vince Becquiot
    July 24, 2007 at 2:36 am
    Look 2 posts above. That technic should get you just what you want.
    It’ll even take care of the low and high pass frequencies.
    Vince
  • Beatcow
    July 24, 2007 at 7:15 pm
    These tricks worked like a charm! Thanks for your suggestions
