Activity Forums Apple Final Cut Pro Legacy Making audio sound muffled
  • Making audio sound muffled
    Posted by Jeff Bruno on July 21, 2009 at 9:47 pm
    I recorded some audio for a short film I’m doing that I want to sound muffled.
    The situation is that a woman is being held under a tarp and she is screaming from under neath it.
    I want the clear audio I have to sound like it should for that situation….
    I tried using the equalizer… but either wasn’t putting it at the right settings, or I don’t know…
    Can anyone suggest a better filter(s) and roughly what number values would be good to set them at?
    telling me to ‘play’ with them isn’t helpful, because i’ve tried that and haven’t gotten close to what I want
    thanks,
    jeff
    Jeff Bruno replied 17 years, 2 months ago 6 Members · 7 Replies
  • 7 Replies
  • John Fishback
    July 21, 2009 at 10:25 pm
    Use the graphic equalizer and lower the gain of each slider to -20 starting with 20kHz (I think that’s the highest frequency control). When you get down to around 5kHz you’ll want to start playing with lesser amounts of cut. Keep going lower in freq until it’s muffled to your taste.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Michael Gossen
    July 21, 2009 at 11:08 pm
    How about a Band Pass filter or a Low Shelf? You can isolate frequencies, then work with EQ…
    Michael Gossen
    Helium Digital Media
  • Ray Chung
    July 22, 2009 at 12:03 am
    Try the Low Pass Filter for starters and find a Freq. setting which suits you the best. It will roll off al the freqs. higher than that setting. Then maybe a a High Pass Filter set to around 100-130Hz or so.
  • Michael Gissing
    July 22, 2009 at 12:36 am
    It is always much easier to record the effect as a wild line on the day of the shoot. Talent lies under tarp and presto – it sounds right. Just muffling with EQ isn’t the same thing as you are finding out.
    It could be re-recorded in a booth. You might even try feeding the signal out to a good speaker under a covering and re-recording the signal. There is also convolution processing, but only if you have an impulse sample of muffled under tarp.
  • Ray Chung
    July 22, 2009 at 12:55 am
    Sure….if they can . If he can only work with a dry recording and can’t get the talent to record again….well.
  • Terry Mikkelsen
    July 22, 2009 at 1:55 am
    Re-Amping is the answer. Most often done with guitars, you take the clean signal and run it through an amp/speaker and re-record it. Typically looking for a certain amp/speaker combo, while in this situation you’re looking for ambience/effect.
    Tech-T Productions
    http://www.technical-t.com
  • Jeff Bruno
    July 22, 2009 at 7:40 pm
    Ah, this one gave me what I was looking for!
    Thanks everyone for the responses, I really appreciate it
    -jeff
