Activity › Forums › Adobe After Effects Expressions › Making audio react to opacity
  • Making audio react to opacity
    Posted by Dumeyni Arnaud on July 24, 2008 at 1:14 pm
    Hi all, thank you for reading this.
    I’m a little noob with expressions and now I just realized i REALLY a noob.
    I’m trying to make the audio level of a sfx go up and down along with one layer’s opacity : when the opacity go down, the audio goes up, and vice versa.
    I linked the audio level to the opacity, plus a linear expression :
    temp = thisComp.layer(“fond anime.avi”).transform.opacity;
    [temp, temp];
    S=linear(temp,0,100,-48,0);
    [S,S]
    But the audio levels aren’t changing.
    Any ideas ? Please.. I can do your laundry 🙂
    Lloyd Alvarez replied 18 years, 2 months ago 2 Members · 3 Replies
  • Lloyd Alvarez
    July 24, 2008 at 9:09 pm
    you don’t need the temp array, but it should work regardless. try this:
    [S,S]
    -Lloyd
    https://aescripts.com
  • Dumeyni Arnaud
    July 25, 2008 at 1:57 pm
    Thanks Lloyd, I’ve tried but its not working.
    I tried it again in a freshly created comp ( the solid and the audio ) its still didn’t worked.
    Its ok I just keyframed the audio level manually but i’m still curious why a simple expression like this didn’t worked out.
  • Lloyd Alvarez
    July 25, 2008 at 1:59 pm
    where are you applying the expression? it works for me here
