Making animation “like-stop-motion” through Vegas + Inkscape
Andreas Vlasov replied 14 years, 3 months ago 4 Members · 13 Replies
Carlos Silva
January 9, 2012 at 8:36 pmHi,
SWISHmax seems to be useful tool. I took a look on that and in your tutorial.
After more research, I found MS PowerPoint 2010 has the “power” of creating animated charts. Moreover, the software can export videos (WMV format). Follow an chart animation example:
https://www.youtube.com/watch?v=buCXgYMaZSE&feature=related
Considering the use this kind of video (with white background), how to remove the background inside Vegas (using Vegas tools)? The idea is use the animated chart above other background. Is it related to chroma key? Considering it possible, could I use the same to WMV or AVI formats?
Thanks in advance,
Cadu
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
John Rofrano
January 10, 2012 at 4:37 pm[Carlos Silva] “Considering the use this kind of video (with white background), how to remove the background inside Vegas (using Vegas tools)? The idea is use the animated chart above other background. Is it related to chroma key? Considering it possible, could I use the same to WMV or AVI formats?”
Yes, you would need to use the Chroma Key tool to key out the white background and make sure that you don’t use white anywhere in your animation. Uncompressed AVI files would work better than WMV because WMV is so highly compressed you might not get a clean key.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Andreas Vlasov
May 18, 2012 at 5:09 pmDoes it support APNG? Gif is too old, and quality of animation frames is too low. 256 color isn’t enough.
[John Rofrano] “The easiest way to add animation would be to use animated GIF files.”
Check my great online service for animation making.
