Activity › Forums › DVD Authoring › Making an uncompressed DVD
  • Making an uncompressed DVD
    Posted by Nicola Di pietro on September 30, 2008 at 5:47 pm
    Hello!
    Could you give me an advice?
    I have two Final Cut Studio projects, shooted using Mini HDV tapes of a JVC HD100E camcorder. Shooted at 720p.
    I use DVD Studio Pro.
    Once finished the editing, I need to burn a DVD for each video, downscaling to SD.
    Each video lenght is <5 min.
    So, I think that if a DVD can store two hours of SD video, and a video of mine is a 4 minutes video, I could make an "uncompressed" DVD!
    This because I need the maximum quality, and since the project is already compressed once (the HDV minitape), if I make a DVD I compress it twice!
    Even if a very low compression ratio, it loses quality a lot!
    DVD Studio Pro hasn't any option like an "uncompressed DVD", or to reduce the compression to zero (like the Win Zip "zero compression - store" option...).
    Could you give me any advice? Is there a software? a plug-in? Freeware or trial is better...
    Thank you!
    Nicola Di pietro replied 18 years ago 2 Members · 2 Replies
  • Michael Sacci
    September 30, 2008 at 6:09 pm
    There is no such thing as an Uncompressed DVD. all DVDs use mpeg2 video. So if you want to be able to play the DVD in a set top player or DVD software nothing you can do differently.
  • Nicola Di pietro
    September 30, 2008 at 6:13 pm
    OK Michael,
    thank you very much!
