Activity › Forums › Maxon Cinema 4D › Making an Oval/egg..
  • Making an Oval/egg..
    Posted by Kelly Johnson on March 2, 2008 at 5:43 pm
    I’ve never been really sure exactly how to either stretch an Torus or Sphere into a more oval shape.
    By scaling, that is.. instead of making it editable and then having to select half the points and move them.
    I can’t seem to select just the Y for example and visually drag the axis to distort the shape more towards an egg/oval shape
    What am I missing?
    Brian Jones replied 18 years, 6 months ago 4 Members · 3 Replies
  • Nolan Scott
    March 3, 2008 at 12:48 am
    Try this:
    Create a Sphere and make it editable and go into Points-Mode /
    from the Structure-Menu select the Magnet-Tool /
    in the Attributes-Manager maybe change Mode to “Dome” or “Bell” and the Radius maybe to “150m” /
    in the Toolbar uncheck X and Z and move the top point of the Sphere upwards /
    maybe experiment with the other settings as well /
    maybe drag the Sphere into a HyperNURBS for even more smoothness.
    Cheers
    Nolan
  • Adam Trachtenberg
    March 3, 2008 at 5:29 am
    Here’s a couple more ways to do an egg:
    1) Create a cube, make it editable, scale down the top face, and drop it in a HyperNURB object;
    2) Create a sphere, make it editable, scale it up a little in Y, apply a taper deformer.
    AdamT
    Cinema 4DXL8 Bodypaint
    *Remember: Tues. is national Shoe Day. Wear shoes to show your support for bimetalism and the designated hitter rule!*
  • Brian Jones
    March 3, 2008 at 11:27 pm
    and more…
    Create a sphere but scale it with the Attribute Manager settings not the axis. Then you can apply a Taper.
