Activity › Forums › Maxon Cinema 4D › Making an object (with splines) editable
  • Making an object (with splines) editable
    Posted by Daniel Gómez on May 27, 2013 at 12:00 am
    Hello everyone!
    When I’m working with splines and then I use Extrude NURBS, Loft NURBS or whatever in order to make geometry with splines, I get the main object and, separately, its two caps.
    https://images.creativecow.net/251114/dudac4d2.jpg
    I would like to know how I can set the two caps in the main object, to turn everything into a single object, without afecting its original geometry. I’ve tried using the “Connector” tool, but I’m not getting a good result with it.
    Sorry for my english and thank you very much for your help 🙂
    Daniel Gómez replied 13 years, 4 months ago 2 Members · 2 Replies
  • Brian Jones
    May 27, 2013 at 3:52 am
    Connect puts all the parts into the same object but does not ‘join’ them (because there are times when that’s a good thing) select all the points of your Connected object and run Optimize, that should join the parts together into one continuous piece.
  • Daniel Gómez
    May 28, 2013 at 11:16 am
    Thank you very much for answering, Brian
    I’ve done what you said, and even though I got just one piece, I’m having the same problems with the shape of the object. You can see it in this picture, at the bottom of the bottle:
    So, is there any way to join the object and its caps together and keep the original geometry untouched?
    Thanks again! 🙂
