Activity › Forums › Adobe After Effects › Making an entire video glossy.
  • Making an entire video glossy.
    Posted by Kesiena Uvietaire on April 19, 2010 at 9:18 pm
    Hello creative geniuses, I have an already edited and rendered musical video in mpeg. How can I make this entire video a bit GLOSSY and sharper with AE? I need help.
    Thanks.
    Chris Wright replied 16 years, 5 months ago 3 Members · 2 Replies
  • Steve Roberts
    April 20, 2010 at 12:04 am
    Also consider applying the curves effect … make an “S” with the curve. Adjust until you like it.
  • Chris Wright
    April 20, 2010 at 2:50 am
    You can also try generate-cc lightsweep or a white solid layer set as mode: soft light, with generate ramp set to radial. Then for sharpening, add a new adjustment layer with blur and sharpen-Unsharp and/or use curves to increase contrast. Glow or bloom lights and darks might work too, depending on the look you want.
    https://technicolorsoftware.hostzi.com/
