Activity Forums Adobe After Effects Making an AE Template
  • Making an AE Template
    Posted by Subspecies on July 19, 2006 at 6:24 pm
    Hi all,
    I’m trying to make an AE template, so when the user opens AFter EFfects, 3 folders will already be made in the Project Window (finals, media and artwork)
    is there a way to do this?
    help
    Eddy Alvarez replied 20 years, 2 months ago 4 Members · 3 Replies
  • Death_or_glory
    July 19, 2006 at 7:22 pm
    Don’t know of a template feature in AE, but another way to do it would be to create a project, make any number of organizational adjustments, and save as ‘job_template.ae’ or whatever.
    Each new job, open this file and ‘save as’ to another location.
  • Filip Vandueren
    July 19, 2006 at 11:28 pm
    the Mac os (both 9 and X) have a setting called: “Stationary Pad”: it’s under the general settings when you hit Command-I or Get info in the finder.
    What this does it that when you double-click this file, you won’t open the file, but an “untitled” or “_copy” version of it, so you can’t accidentally save over the original, it’s always a copy.
    I’m sure Windows should have something similar hidden somewhere buried in a tab.
  • Eddy Alvarez
    July 20, 2006 at 7:55 pm
    dante…
    aahron rabinowitz has a Creative Cow AE podcast that talks about this.. i believe its named ‘AE Tips : organizing your workflow’ or something to that nature..
    check it out.
