Activity › Forums › Adobe After Effects › making an Adjustment layer not effect a layer??
  • making an Adjustment layer not effect a layer??
    Posted by Mark Linthicum on March 22, 2010 at 7:19 pm
    I thought there was a way you could make a layer not be effected by an adjustment layer? I remember this functionality was added in AE a few years ago.
    Anyone know how to do this, cant find it in the manual.
    Thanks Mark
    Brendon Murphy replied 5 years, 11 months ago 8 Members · 7 Replies
  • 7 Replies
  • Todd Kopriva
    March 22, 2010 at 9:45 pm
    Dave is right. Perhaps it will help to understand how adjustment layers work:
    An adjustment layer works by rendering all of the layers beneath it into a single composite and then applying an effect to that composite.
    So, from this, you can see that it doesn’t really make any sense to think of one of the layers beneath an adjustment layer being excluded. The adjustment layer doesn’t see individual layers at all; it just sees the one composite image that it’s operating on.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Rusty Shackleford
    January 4, 2012 at 11:45 pm
    It would be nice to have an adjustment layer not affect a specific layer beneath, like some footage for a key.
    Brandon Morris
    http://www.brandonmorris.com
    Canon T2i
    13″ Macbook Pro (Mid 09) 8GB RAM 10.6
  • Stan Becker
    January 11, 2012 at 4:03 am
    Just precompose the adjustment layer with all layers you want it to effect.
  • John Drago
    February 9, 2012 at 4:09 pm
    I was looking for that exact solution. I needed the adjustment layer to affect only the layer beneath it (for hue color changes) and that worked perfectly – just pre-compose the adjustment layer along with the layer you need “adjusted” and it will work anywhere in the layer stack without affecting anything else.
  • Sergei Venturinov
    November 20, 2017 at 5:38 pm
    For the record, this can be achieved by pre composing what you want to be affected in a separated Comp and then introducing it into the new one. This way you can include elements below your affected layers that stand unaffected.
  • Santanu Bhattacharjee
    October 9, 2020 at 5:35 pm
    If we need to pre-compose anyway, we could apply all the filters to the pre-composed layer from outside. Then there is no difference between adjustment layer and a pre-composed layer. I still did not understand the advantages of adj layer over precomposed layer, expect for not having to go else where to edit. Hence a field/ parameter to avoid the layers to be affected should have been there in an adj layer.
  • Brendon Murphy
    October 10, 2020 at 10:10 pm
    You could, of course, apply the effect directly to all desired layers. Then parent all of those effects to one on a “control layer” at the top of the comp so that you can make tweaks without needing to adjust each layer individually. The control layer can even be a null object, or solid with zero opacity, so it doesn’t mess anything up.
