Activity › Forums › Adobe After Effects › Making a wall of text with a bend in it
Posted by Walkinginspace on August 16, 2005 at 10:16 pmI need a wall of continuous text that looks like it bends and heads down the other side of the wall. Like if you were looking at a wall and the text crawled along one wall then continued on to the other wall bending in the corner. Is there a way to do this?
Walkinginspace replied 21 years ago 2 Members · 8 Replies -
Serge Hamad
August 16, 2005 at 11:15 pmHi,
It’s possible if you have Invigorator.
Here is a simillar thread:
https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=2&postid=565206&archive=T
Otherwise you would have to fake it using 3D layers.Salut.
Serge -
Serge Hamad
August 17, 2005 at 2:53 amHi Steve,
I would rather use Invigorator if I was you but here is the 3D fake:
https://www.nyc-visual.com/text_around_corner.sitLooks like this:
https://www.nyc-visual.com/text_around_corner.movNotice the position Kfs for the text.
I hope this may help.
Salut.
Serge -
Walkinginspace
August 17, 2005 at 3:27 amthat’s the look. thanks for the help! The reason i don’t want to use invig is that there is going to be tons of text and there will be nothing in the background, just text over white, sorta like what FOX does with there logo, just 3d text bending around. There will be walls of text floating around.I’m sure there’s a way to do this easier, but i haven’t figured it out….thanks again for the help!
Walkinginspace
August 18, 2005 at 5:04 amYour example works great but for one thing. If I get the 3d camera close to it, the edges fuzz out! Total bummer because I thought I had it whipped, any ideas on getting the text to rasterize correctly or is that beyond the limits of basic text? I tried using the new text in AFX but you can’t really make it clip outside it’s boundries like just having basic text on a solid…or is there a way to do that? Thanks for the help…we’re so close!
steve
Serge Hamad
August 19, 2005 at 6:28 pmHi,
Here is how you can do it with the text tool:
https://www.nyc-visual.com/text_Around_Corner_Sharp.zipIf you need explanations let me know.
Salut.
Serge -
Walkinginspace
August 22, 2005 at 3:07 amOnly explanation would be how do you get the timing right on making them look seemless. I can do it but it takes a lot of trial and error….is there a easy solution for it?
Walkinginspace
August 23, 2005 at 9:53 pmafter really close examanation of your file i see that one of the layers has a keyframe with a little
x under it and the pixel speed is different. Can you explain what you did there? I’m curious
what these settings are…thanks for your help.
