Activity › Forums › Adobe After Effects › making a text spin using 3d camera ?
  • making a text spin using 3d camera ?
    Posted by Rajarshi Basu on February 9, 2007 at 4:39 pm
    hi,
    i have created a text in in 3d space, now i want to rotate the TEXT on its axis using the axis tool. but every time im trying to manually keyframe it and spin it, the z axis changes and the text zooms in really big!!
    is there a simple way to do this apart from manually keyframing it? like setting the 3d rotation evolution somewhere ?
    im facing this problem… to which there is a simple solution, but i cant get it right now…
    Todd Morgan replied 19 years, 7 months ago 2 Members · 4 Replies
  • Rajarshi Basu
    February 9, 2007 at 5:43 pm
    dave,
    nope…nothing that complicated.
    If you have seen Andrew Kramer’s SeriousFX podcast, where he creates 3d titles…the 3d light streams…
    https://www.videocopilot.net/tutorials.html
    I want to make the text “SERIOUS FX” spin around really fast and make it come to a stop using easy in keyfrmaes.
    Raj
  • Rajarshi Basu
    February 9, 2007 at 6:09 pm
    thanks dave
  • Rajarshi Basu
    February 9, 2007 at 8:10 pm
    dave,
    i tried your suggestion, but im still getting that zoom effect when i spin it. its very stupid…but do i require some other plugin for this simple thing ? or can you please point me to a tutorial of some sort where a similar kind of effect is done ?
  • Todd Morgan
    February 9, 2007 at 9:41 pm
    Have you solved your problem?
    Todd Morgan
    morgancreative
