Activity Forums Maxon Cinema 4D Making a stretched texture look even all around it
  • Making a stretched texture look even all around it
    Posted by Scott Green on October 12, 2012 at 9:32 am
    Hi, I’m just doing a test with Sweep Nurbs and applying a texture to it.
    My question is; I want the texture that I apply to look even all around it and not look like it’s stretched on the bends and shrunk at the ends when the fillet caps are as in this screenshot:
    How would I go about achieving a nice even texture all over my over my model?
    Here’s the model with it’s texture in case you need it:
    4788_ws.c4d.zip
    Thanks.
    Creative Multimedia Design Manchester | S©tt Green | Splurj
    Sean Simon replied 13 years, 9 months ago 3 Members · 3 Replies
  • Brian Jones
    October 13, 2012 at 5:56 pm
    if it needs to follow the shape of the object (UVW mapping) you have to accept stretching in the bends but you can limit the apparent length of the stretch by tiling the texture on the object. To get the caps to tile the same as the rest of the object you’d have to apply separate textures on the caps with different settings.
  • Scott Green
    October 13, 2012 at 6:58 pm
    I’ll give that a bash, thanks a lot for your reply.
  • Sean Simon
    December 3, 2012 at 4:14 am
    Hello Scott, an easy way to help you is by going into the texture tag on the object and messing around with the Projection.
