Activity Forums VEGAS Pro Making a Stills from video
  • Making a Stills from video
    Posted by Bernard Ageeb on December 12, 2005 at 10:29 pm
    I Have a client who wants me to get photos from there wedding video from which ihave done , because the photographer photos were bad.What is the best way to get high quality photos from vegas 6 so they can get them printed? Thanks in advance
    Bernard
    Edward Troxel replied 20 years, 9 months ago 3 Members · 3 Replies
  • Peter Wright
    December 13, 2005 at 12:43 am
    First, set preview to Best/Full. This will allow max quality at the full video size.
    After capturing pngs or jpgs, you may need to deinterlace in a paint program if there is movement.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Bernard Ageeb
    December 13, 2005 at 1:06 am
    Thanks Peter i will try that.
    Bernard
  • Edward Troxel
    December 13, 2005 at 2:34 am
    For the best snapshot possible from Vegas, there’s multiple settings to change. The EASIEST way to do that is to use a script which will change those settings, save the snapshot, and then reset the settings. For more info on that, look at vol 1 #5 of my newsletters.
    Also, note that you probably don’t want to go above 4×6 as standard DV-AVI is not very high in resolution. If you have HDV, you may be able to go a little larger.
    Edward Troxel
    JETDV Scripts
