Activity › Forums › Adobe Illustrator › Making a simple, specific shape to export to After Effects
  • Making a simple, specific shape to export to After Effects
    Posted by Victoria Murphy on July 20, 2009 at 2:36 am
    I am experimenting with different ways to create a mask effect in After Effects CS3. Toward this end, in Illustrator CS4 I want to create a rectangle of specific pixel dimensions, skewed to a specific angle, and import it to AE. I need a little help doing so, as my Illustrator skills are primitive and I need to compensate for pixel aspect ratio, which I don’t thoroughly grasp.
    In AE I want the dimensions of the rectangle to be 1200 pixels wide and 480 pixels tall; I want to skew it 45 degrees to the right. Can you tell me how to create in Illustrator a rectangle of this size, skewed in this manner, so I can import it to AE?
    (I tried to make and Illustrator document set to film & video settings and make a rectangle as described. I got stuck.)
    Many thanks.
    Vincent Rosati replied 17 years, 2 months ago 2 Members · 3 Replies
  • Vincent Rosati
    July 20, 2009 at 11:28 am
    Basically two ways.
    You can press ‘M’, to activate the Rectangle Tool, than click on the artboard. A dialogue box will appear, and you can input the dimensions in px (1200 px, etc.).
    Or, if you already have a rectangle on the artboard, you can select it and open the Transform window, and enter the W and H dimensions there.
    To skew, again, select the object. And in the Transform tab, you’ll notice a little icon of a box made of 9 boxes. Probably selecting any of the 9 anchors will work. Than enter 45 degrees as the Shear angle.
    Hope this helps.
    Vince
  • Victoria Murphy
    July 20, 2009 at 6:13 pm
    Thanks, Vince.
    I followed your instructions and did make the rectangle, as needed. I imported it into AE and did not get the result I was looking for. I think I’ll head over the the AE forum and see if I can get some suggestions there.
    Best,
    Victoria
  • Vincent Rosati
    July 20, 2009 at 7:30 pm
    you’re welcome
    Vince
