Activity Forums Adobe After Effects making a PSD file into a 3d plane with bumps
  • making a PSD file into a 3d plane with bumps
    Posted by Howie Chin on July 15, 2006 at 6:46 am
    Im trying to make a video of this flying on a road in AE..i have a piece of road done in Photoshop. I intend to bring it into AE to make it as if the road leads up to a cliff. So it makes a slope. What im havin now is just a flat plane of road. i need to make it look uneven. A little wavy when u look at it…
    Is there any plug in’s i need to use?
    thnks
    [howie]
    Jon Okerstrom replied 20 years, 2 months ago 4 Members · 3 Replies
  • Michael Szalapski
    July 15, 2006 at 4:22 pm
    You can make it a 3d plane, but you won’t get bumpiness. You could possibly get waves in the road with a plug-in from Digital Anarchy called3d Layer, so purchase and have fun.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great)
  • Mike Clasby
    July 15, 2006 at 5:02 pm
    Re:Shade/Shape will do what you want:
    https://www.revisionfx.com/rsshade.htm
    Check out the demo.
    Use another layer as the “Shape Alt Source”, most examples in the gallery use Alpha, not what you want.
    I put Ramp on a new layer precomped it as use it as above for a eerily symmetrical dome mountain.
    The Plugin also does bump mapping using a source of you choice. It can give some pretty amazing results, I got a fur-like effect from a course sand bump map and the right tweaking.
    The only tricky part is learning what maps give what results.
  • Jon Okerstrom
    July 16, 2006 at 1:30 am
    An oldie but a goodie in this case would be Forge Freeform.
    Jon
