Activity › Forums › Adobe Photoshop › Making a ‘precomp’ layer in PS CS 2?
  • Making a ‘precomp’ layer in PS CS 2?
    Posted by Nathan Quattrini on February 14, 2007 at 5:50 pm
    Is it possible to make a layer that uses a group as like a precomp like you can do with Premiere? In premiere you can import one sequence into another and alter it as a whole. Is there anyway to do this in PS? What I have and need to do is take my file that is about 900×900 and crop it to 720×480. However I don`t want to crop and save because if i need to go back and make changes i`ll be in trouble, and even cropping then undoing several times until things are right is very tedious.
    Mike Gondek replied 19 years, 7 months ago 2 Members · 3 Replies
  • Mike Gondek
    February 14, 2007 at 8:13 pm
    Thanks to smart objects you can do this.
    Just place your 900×900.psd file into your 720 x 480 file.
  • Nathan Quattrini
    February 14, 2007 at 10:39 pm
    so it still needs to be 2 seperate .psd files though right? Its close enough to what i need if thats the case
  • Mike Gondek
    February 15, 2007 at 5:46 pm
    That is the closest way I know of to simulate the After Effects Precomp in Photoshop. This way if you need to change your first file, it will update in your 2nd file. Every other method I know of requires 2 files.
    You can get rid of the original file if you really wnat to, but I find it best to keep it rather than editing the smart object through the layers palette flyout menu option.
