Activity › Forums › Maxon Cinema 4D › making a polygon plane a bit thicker
  • making a polygon plane a bit thicker
    Posted by Nicolasbuechi on August 7, 2007 at 7:39 am
    hello and good morning
    i have the following question:
    i have a plane, but i deformed it, so it has now the form of a v.
    no i want it to give it some thickness, so around one 1cm thick. how can i do that? i have it already converted to polygones.
    thank you for your answer.
    nicolas
    Nolan Scott replied 19 years, 1 month ago 3 Members · 2 Replies
  • Randy Johnson
    August 7, 2007 at 9:53 am
    -You will have to move points in the direction you want it to be thicker.
    -Or you could copy and paste it move it 1cm and bridge them together.
    -You could take a CUBE squishing it down to be the thickness you want then deforming it.
    -Personally I would use a spline inside a sweep nurb with a square. The square then can be adjusted to the size you want. And then if you need to modify it more you can make it polygon object…
    https://www.randyarchy.com/V.c4d.zip
  • Nolan Scott
    August 7, 2007 at 9:59 am
    Try this:
    Deselect all your polygons / but stay in Polygon-Mode /
    Go to Structure/Extrude /
    In the Attributes-Manager (Offset should be 1 m) (and check Create Caps) /
    Hit Apply.
    Cheers
    Nolan
