Activity Forums Apple Final Cut Pro Legacy Making a PAL DVD
  • Making a PAL DVD
    Posted by Mark Richford on June 26, 2009 at 11:53 pm
    I want t make a couple copies of a wedding video for my buddy’s mom in England.
    SD DV NTSC project:
    Got a general error when trying to export a QT with PAL settings, so I guess that was wrong.
    If a change sequence settings(to PAL-DV 48) I, of course, have all kinds of cropping issues.
    So what’s a mother to do. It’s simple, right? Well I don’t get it. When someone gets a minute…thanks:-)
    Todd Dalton replied 17 years, 2 months ago 6 Members · 12 Replies
  • 12 Replies
  • John Pale
    June 27, 2009 at 12:40 am
    Pretty much all PAL tv’s and DVD players play NTSC. If she has a problem , you can use the Nattress Standards Converter plugin ($99) or Compressor (extremely slow, but free and good quality) to convert to PAL and make a PAL DVD.
  • Mark Richford
    June 27, 2009 at 12:44 am
    Yeah, that’s what I thought. But alas, no. Will try with Compressor. Thanks
  • Eric Pautsch
    June 27, 2009 at 2:11 am
    You’re pretty much wasting your time and quality. Give them an NTSC disc and you will be fine. Virtually all PAL player play NTSC discs.
  • Mark Richford
    June 27, 2009 at 2:22 am
    But the folks across the pond are complaining of “big, green blocks” on their screen
  • Mark Richford
  • John Pale
    June 27, 2009 at 4:10 am
    What bit rate did you encode at? Did you encode your audio to AC3
    That could be an entirely different problem
  • Mark Richford
    June 27, 2009 at 4:29 am
    When exporting a QT from the NTSC timeline/sequence?
  • John Pale
    June 27, 2009 at 4:50 am
    [Mark Richford] “When exporting a QT from the NTSC timeline/sequence?”
    No. When encoding your Quicktime in Compressor to MPEG-2 and AC3 to make your DVD.
  • Mike Smith
    June 28, 2009 at 10:20 am
    It’s just so not true that all DVD player/screen combinations in PAL land will play NTSC discs. Some will, many will play a hybrid near-decent version (NTSC 4.43) which some screens show OK and some not, a few older players and many older screens (there are lots of them) won’t show anything at all.
    From a PAL land resident!
  • Arthur Ross
    June 28, 2009 at 3:26 pm
    Mark,
    I have done some conversion from NTSC to PAL of my kids’ dance recitals. I live in Belgium, shot multicamera and had some good footage and cut a simple video for the moms and dads.
    I was able to use Compressor to convert an FCP sequence to MPEG-2 PAL imported to DVDSP to complete the project. When you get the NTSC sequence opened in Compressor, you can change the format in the Inspector window, 2nd tab, if I remember correctly.
    Have you tried Compressor yet? Any luck?
    Art
