Activity Forums VEGAS Pro making a PAL dvd in Architect
  • making a PAL dvd in Architect
    Posted by Al Kohout on April 27, 2007 at 2:07 pm
    I made a NTSC MPEG…it then rendered a new project…
    uisng DVD Architech with menus, etc…all is good..
    now I wish to have a PAL verion of the SAME project. what is the best and easiest way to do this? ( I dont use VEAGS, so making it in Vegas is not viable)
    I had originaly thought to make new PAL project in ARCHITECT using the old MPEG file so..it made the DVD but it played fine in my AMERICAN DVD player…so I must have made a mistake…
    is it PAL or NTSC ?
    should I start over? I already had the menus, etc in the NTSC DVD Architect version..and don’t wan to lose that version
    so just want a PAL version as well.
    Gary Kleiner replied 19 years, 3 months ago 2 Members · 1 Reply
  • Gary Kleiner
    April 27, 2007 at 2:17 pm
    You need both a PAL mpeg file and to set the project properties in DVDA to PAL.
    However, it is not desirable to recompress your NTSC mpeg to make a PAL version of it. Go back to the original project where you created your NTSC mpeg and render it as PAL instead.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
