Activity › Forums › Adobe Encore DVD › Making a PAL DVD but getting unwanted pillarbox
  • Making a PAL DVD but getting unwanted pillarbox
    Posted by Robert Haynes on June 14, 2012 at 7:00 pm
    I’m kind of new to Encore and I’m having trouble with a PAL DVD. My source is a 720×576 letterboxed m2v PAL file. The problem is when I bring it into Encore, Encore is also pillarboxing it so that it has black around the entire file. The source is not pillarboxed. How can I fix this?
    A little detail about the project. It’s a simple first play PAL DVD with one m2v video asset. No menu. I have the project settings set to:
    Authoring mode: DVD
    Television Standard: PAL
    Transcode Settings: Codec: MPEG-2; Dimensions 720×576; Frame Rate: 25; Fields: Lower Field First; Audio Transcoding Scheme: Dolby Digital; Maximum Audio/Video Bitrate: 9.4 Mbps
    Thanks for any help.
    Daniel Ludwig replied 14 years, 3 months ago 2 Members · 3 Replies
  • Daniel Ludwig
    June 17, 2012 at 1:55 pm
    robert,
    first of all – your bitrate is much to high. 9.4Mbit will not work on burned discs, the max. bitrate would be 8.5Mbit (video and audio incl.).
    what do you mean by letterboxed? anamorph 16:9 or letterboxed 4:3?!
    PAL-DVDs will only be lower first as the source-material is DV-material, DV, DVCPRO25, DVCPRO50 or DVCAM. all other PAL-source is upper field first.
    if the original is 16:9 letterboxed, you need to encode the MPEG2 as 16:9 using adobe media encoder or any other encoder.
    cheers
    danny
  • Robert Haynes
    June 19, 2012 at 5:46 pm
    Hi Danny. Thanks for the response. The file is neither anamorphic or letterboxed 4:3. It is PAL 720×576 letterboxed with a 16:9 video. I’ve already encoded the original which was a DVCPro HD file. When I bring it into Encore, Encore is adding a slight pillar box on the sides of the frame making the entire 16:9 video be surrounded in black.
  • Daniel Ludwig
    June 19, 2012 at 9:36 pm
    robert,
    if it´s a real 16:9 PAL-clip it IS anamorph, as 16:9 with aspec 1:1 would be 1024×576 instead of 720×576.
    but if your source is DVCPRO HD, this is HD and need to be scaled to SD prior encoding, and if it is 1080i50-source, it needs to be cropped left and right to fit to 720×576.
    what encoder do you use to create your PAL SD MPEG2? adobe strangely using a different aspec-ratio (1050×576), but your encoded file will be 720×576 as well.
    are you using adobe media encoder?
    NOTE: DVCPRO HD has a native resolution of 1440×1080 instead of 1920×1080, it´s an anamorph HD-resolution.
    cheers
    danny
