Activity › Forums › Apple Final Cut Pro Legacy › Making a music video with only still images.
  • Making a music video with only still images.
    Posted by Fridtjof Nilsen on November 26, 2009 at 2:08 pm
    Hey.
    I’m making a music video consisting of approximately 7000 jpg still images.
    I’m looking for a way to edit the duration of groups of images in a simple way. Will nesting be a good solution?
    Is it possible to nest a number of images, edit them as that and then make them separate images again without loosing the changes made?
    Any tips on what format I should make the movie in to make it good enough for tv broadcast?
    Any help would be fantastic 😉
    joff
    Rafael Amador replied 16 years, 10 months ago 4 Members · 4 Replies
  • Steve Eisen
    November 26, 2009 at 8:02 pm
    What is the duration of your stills? 1 frame (import as image sequence) or 1+ seconds?
    You can set the duration of your stills before you import them in your FCP preferences.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Fridtjof Nilsen
    November 26, 2009 at 11:03 pm
    Hey Steve.
    The stills are now 2 frames each.
    What I’m wondering is if it’s possible to link a number of stills and change the duration of them as a total in a simple way.. Preferably while still having them as separate images. I can nest them and do it, but how can I get them back to separate images?
    Thanks for helping me out 😉
    joff
  • David Bogie
    November 27, 2009 at 3:59 pm
    Without knowing something about your stills and how you intend to release the project, it’s only possible to makie a few basic suggestions. If you bring your stills in as image sequences (beyond the scope of this post) you can always change the duration of each image using time remap. But that involves a bunch of planning.
    That’s what this kind of production is all about, basic and fundamental planning. How large are your stills?they should be no larger than absolutely necessary for your release format or you will bog down your system. here is an infinite number of threads here on the cow for working with still images in FCP, AE, Motion, and other applications. Even for a “music video” you must have purpose and you will want a visual climax of some kind, a reason, a reward, for your viewers. Developing and producing your story is beyond the scope fo this thread, too.
    You will not want to try to edit 7k stills in a single sequence. You will want to break it down into manageable clumps. Imagine you are sending segments to a bunch of creative editors who are all working independently of each other.
    You want to work in a future-proof format so you can release in any format someone might request but you still must work within the abilities of your system.
    bogiesan
  • Rafael Amador
    November 28, 2009 at 2:52 pm
    I agree with David that you have to plan well your steps from the beginning.
    If would be possible I would just consolidate all in a clip with a good codec.
    7000 stills is a less than 4 minutes clips, easy to manage.
    7.000 stills in FC is another story.
    Rafael
    http://www.nagavideo.com
