Activity Forums Adobe After Effects making a logo look like fireworks
  • making a logo look like fireworks
    Posted by Afrancis on December 16, 2007 at 10:50 pm
    Hi Does anyone know how to make this logo (just the red part)look like a firework? https://www.dpacoms.com/images/finallay/Experience/Casestudiespic/hamleys.jpg
    Basically I trying to make the letters sparkle after exploding abit like those fireworks with writing. I am after 3 different firework explosions. One normal fire work in one corner of the screen the second in the other corner of the screen and the grand finale of the logo firework in the centre. I have the original logo if anyone wants to have a try.
    Tony Ash replied 17 years, 12 months ago 4 Members · 7 Replies
  • 7 Replies
  • Steve Roberts
    December 17, 2007 at 1:31 am
    I think you might need to buy Trapcode Particular for this. It allows you to use a layer as a Particle emitter. You could hide the logo layer, use it as an emitter, then fade up another logo layer to resolve it at the end.
    Anyway, here’s something on the Trapcode site that might help you:
    https://www.trapcode.com/help/particular/layer_emitter.html
    You might want Trapcode Starglow as well.
  • Afrancis
    December 17, 2007 at 12:35 pm
    Hi Steve, i do have trapcode particular. Could you write a brief step by step on how to do this? so that i can fiddle around with it
    regards
    Alison
  • Steve Roberts
    December 17, 2007 at 8:56 pm
    Try this:
    1. The logo has to be a layer with transparency around the letters. Add it to the comp. Make it 3D.
    2. Add a camera.
    3. Add a solid to the comp and apply Particular. Leave it as 2D, of course.
    4. In Particular, set the emitter to the logo layer, set the direction to Directional, and set the particle type to Glow Sphere. Add a bit of gravity.
    5. Maybe apply stylize>glow to the Particular layer.
    That’s it. After that, you’ll want to tweak it for the look.
    Now that’s the best that I can do here, but if you Google “trapcode”, “particular” and “fireworks”, you’ll get more info, including some presets and projects. You might also check the Trapcode COW forum.
  • Afrancis
    December 17, 2007 at 11:15 pm
    Thanks so much guys, im working on it now, i will let u know how i get on
    regards
    Alison
  • David Bogie
    December 18, 2007 at 11:06 pm
    Can also be done with CC Particle — umm, I forget which one — you can use the alpha of a layer as the emitter shape. Not nearly as flexible and lovely as Trapcode’s particle options but I use CC particle systems often (cuz I odn’t have Trapcode).
    bogiesan.
  • Afrancis
    December 18, 2007 at 11:28 pm
    hi i still am a bit new to AE so could you please write how to do that in steps. also is cc particles in AE 6.5?
  • Tony Ash
    September 19, 2008 at 10:30 pm
    i did a search for fireworks on https://www.planetaep.com they do some after effects projects that have fireworks and some logos without any plugins
