Activity Forums Adobe After Effects making a line wiggle
  • making a line wiggle
    Posted by Jason Yardley on August 28, 2007 at 2:11 pm
    Hi I’m trying to make a hand drawn line wiggle, (a bit like a line dawing but with a look of sort of scratch animation), I would usally do this in vector paint and put wiggle on it , but I already have the artwork in eps format so I don’t need to draw out the line art, is there anyway to apply the wiggle controls from the vector paint plug in to a already drawn piece of line artwork
    Adriano Moraes replied 19 years ago 3 Members · 2 Replies
  • Kevin Camp
    August 28, 2007 at 2:30 pm
    there are distortion effects like turbulent displace and displacement map (displacement map requires a gradient map).
    i think i might try turbulent displace. it will displace the whole image with a similar ‘turbulance’, so if you want it more irregular distortion, you may want to try and separate your image into a few pieces and apply the effect with different parameters to each piece.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Adriano Moraes
    August 28, 2007 at 2:44 pm
    Well hello there.
    I don
