Activity Forums Adobe After Effects Making a layer play in reverse…
  • Making a layer play in reverse…
    Posted by Beast666 on December 26, 2006 at 11:31 am
    Hello all,
    I am new to After Affects, and currently using version 6.5 Pro.
    I have a AVI clip on a layer, and I applied the Shatter effect to it. I would like to add a second layer and be able to REVERSE the shatter effect. When playing the final combined effect, the shatter occurs and then reverses, returning to the original status of the clip.
    So, I guess my question is . . HOW DO YOU MAKE A LAYER PLAY IN REVERSE ??
    Many thank for your help.
    Michael Duff replied 19 years, 8 months ago 3 Members · 2 Replies
  • Tyler Paul
    December 26, 2006 at 2:14 pm
    There are several ways. Head up to the menu and select ‘Layer’ – ‘Time’ and choose which route you’d like to take. In your case I’d probably time remap for the greatest control over when the layer stops proceeding and starts reversing and the speed at which it does it.
    “Life Should Come With Backround Music”
    -Brown Sugar Studios-
    Tyler Paul’s Toonificator V3.2Example Clip
  • Michael Duff
    December 26, 2006 at 9:28 pm
    don’t forget to pre-comp the layer first . . . . effects like shatter and many others need to be pre-comped before you can apply time effects
