Activity Forums Adobe After Effects Making a layer 3D moves it far away from current position
  • Making a layer 3D moves it far away from current position
    Posted by Andrew Wilson on September 16, 2011 at 4:50 pm
    After a long affair with Motion, I’m beginning to see the light and switching back to my first love, After Effects.
    This is probably an easy preference or button click somewhere but searching the forum for “3D” and “layer” produces way to many results to wade through.
    I’ve got a 3D composition and I’m moving the camera around 3D space (using the amazing SureTarget plug in)
    When I drop a video clip into the comp it’s pretty much right where I want it… until I switch it to a 3D layer, then it jumps to location 0 (or 360, 240, 0 actually)
    Is there a way I can make it so when switching the layer to 3D, it stays in the same relative position as the camera sees at the current time?
    Andrew Wilson
    WestView Digital Video & Design
    http://www.westviewdigital.com
    Andrew Wilson replied 14 years, 11 months ago 2 Members · 2 Replies
  • Kevin Camp
    September 16, 2011 at 8:14 pm
    the problem is likely due to the camera’s position.
    when a layer is 2d, it is relative to the composition frame that you see in preview. as soon as you make it 3d, it is relative to the 3d camera frame.
    you might try switching to multiple viewers in ae (just select one of the ‘4 views’ options at the bottom of the preview window). then you’ll see the front, side, top and 3d camera views of the scene that can help you place layers where you want them.
    you’ll also notice that a 2d layer always faces the front of any viewer, demonstrating the issue of positioning a 2d layer relative to 3d space…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Andrew Wilson
    September 16, 2011 at 9:49 pm
    Thanks. I figured out the best way to do it was to take a layer that was already in that neighborhood in 3d space, highlight POSITION, and ROTATION, then copy and paste those properties onto the layer that just moved beck to zero.
    Andrew Wilson
