Activity › Forums › Zaxwerks › Making a helicopter blade spin
  • Making a helicopter blade spin
    Posted by Mike Schmitt on March 14, 2012 at 6:48 pm
    Hi guys!
    I’m trying to use Proanimator in After Effects to render a 3d Model of a helicopter I bought from Turbosquid.
    I’ve got it all done except the the rotating of the propeller blade.
    I’m in the animation window and have created a separate track for the propeller,
    Using the pose positioning controls advanced menu, I am attempting to rotate the blade on the Y axis and the best I can do is one rotation per key frame. Is that right?
    The helicopter is going to be in the shot for about ten seconds. Is there a way to automate the blade rotating very quickly for the whole shot?
    Thanks for any suggestions!
    MIKE
    Mike Schmitt replied 14 years, 6 months ago 2 Members · 2 Replies
  • Edward Wu
    March 15, 2012 at 12:03 am
    Hi Mike,
    Instead of using the “Rotate Around Common Center” control, try going into Pose Actions, and using the “Spin Y” control. Then you can type in a value for the rotation. Typing in 360 will get you a full rotation while 1080 will get you three full rotations. So keep increasing the value until you get the speed that you need.
    Best,
    Edward
  • Mike Schmitt
    March 15, 2012 at 1:18 am
    Thanks Ed! I knew there had to be an easy solution.
