Activity › Forums › Apple Final Cut Pro Legacy › Making a head explode (special effects)
  • Making a head explode (special effects)
    Posted by Elvisjer on February 20, 2007 at 3:25 pm
    Hey guys, Im working in Final Cut Express not FCP, but i have to post anyways. I’m trying to make a person’s head explode on screen from a bullet. The shot is simply a profile of a guy from the side, shoulders up. I need his head to explode from a digital bullet. I have shots of the background behind him with the same camera positioning too which i imagine would be neccesary for his body there without a head. What would you guys use? I have photoshop too if it would be needed, all in all the head exploding can be as little as 15 or so frames. Thanks!!!
    Jason Porthouse replied 19 years, 7 months ago 7 Members · 8 Replies
  • 8 Replies
  • David Battistella
    February 20, 2007 at 4:28 pm
    I can’t answer this post. It might make my head explode!
    David
    Peace and Love 🙂
  • David Roth weiss
    February 20, 2007 at 4:46 pm
    Since you have the background plate it would be relatively simple to blow off the head completely and leave it on a smoking neck than to blow it up. Blowing it of would simply require a loud sound effect to make the audience blink, a quick cut in mask to mask out the head, a particle effect for the smoke and a bit of painting for some jagged edges and a little blood around the edges.
    DRW
  • Jeremy Garchow
    February 20, 2007 at 4:52 pm
    THere used to be a sweet tutorial that was here on the cow for a day or so, but taken down mysteriously. Following Andrew Kramer’s link that was mentioned above might take you there. you will need After Effects to complete it.
    Jeremy
  • Andy Mees
    February 20, 2007 at 5:40 pm
    as their copy says … Because nothing says “dead” like removing a head
    sound effect, mask off the head and replace it with a free exploding styrofoam head clip from here: https://www.detonationfilms.com/UnitK.htm
    better yet buy one of their “eggsplosions” too and add it to the mix 🙂
    have fun
    Andy
  • Stuart Simpson
    February 21, 2007 at 12:00 pm
    “Is it true that there is a place on a man’s head, where if you shoot it – it will blow up?”
    -Hot Fuzz.
    -Simmie
    2 G5 – Kona LH
    3 G4s – Cinewave
    1 xbox360, 1 PSP, 1 PS2 & a Gamecube
    https://www.speak.co.uk
  • Andy Mees
    February 21, 2007 at 12:40 pm
    not the sort of question you want to hear on a first date
  • Jason Porthouse
    February 21, 2007 at 6:24 pm
    Stick a camera in a room full of editors… and start them talking about aspect ratios. Eventually someone’s head will explode. Job done.
    Jason
  • Jason Porthouse
    Jason
