Activity Forums Adobe After Effects Making a graphic at (25)Fps look smoother
  • Making a graphic at (25)Fps look smoother
    Posted by John Mark on July 31, 2013 at 11:24 am
    I work at a fixed rate of (PAL) 1080i50. So I now have to make graphics at 25fps. This now really eliminates that smooth look when the graphic is in motion.
    Is there anyway I can make the graphic run smoother still at 25fps. Maybe a technique used in after effects?
    I can’t run my graphics at 50fps or 60fps because when on final output via a ATEM TVS set to 1080i50 or HD TV, the graphic jerks, etc.
    I’m running After Effects CS6 on a Macbook.
    Thanks.
    A News Graphic Lover
    John Cuevas replied 12 years, 9 months ago 2 Members · 1 Reply
  • John Cuevas
    July 31, 2013 at 1:52 pm
    Make the graphic move slower/add motion blur.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
