Activity › Forums › Apple Final Cut Pro Legacy › Making a exact copy of a tape.
  • Bouncing Account needs new email address
    November 22, 2005 at 7:44 pm
    You did not say WHAT FORMAT of tape.
    Regardless, you must have a deck that accepts EXTERNAL timecode for the tape copy to have the same TC as the original.
    You then must switch the deck to EXTERNAL TC for it to know to record it.
    If you don’t own a deck with this feature, you may need to take the tape to a production house that DOES.
  • Jeffrey Levenstone
    November 22, 2005 at 8:58 pm
    it Is DV. The only option I have is to use my xl1s as deck.
  • Dean Sensui
    November 22, 2005 at 9:02 pm
    If it’s a DVCam tape there’s a “dup” feature that will make an exact copy from one DVCam deck to another. Keep in mind that both DVCam decks have to have this feature and that the source tape has to be in the DVCam format.
    Dean Sensui — http://www.HawaiiGoesFishing.com
    November 22, 2005 at 9:11 pm
    No it is just dv. I have a xl1s and a xl2.
  • Rocco Rocco
    November 22, 2005 at 9:24 pm
    Hi Jeffrey,
    Perhaps the best thing to do would be to call a duplication facility for a quote and turnaround time. Make sure hey know to produce an exact clone of the master tape. They’ll do a great job and you won;t have to worry about your client etc. It’s only DV, it won’t be that expensive.
    Good luck.
    November 22, 2005 at 9:35 pm
    Thanks everyone for you reactions the suggestion so far. But does this mean that there is noway to do this with final cut pro and my xl1s or xl2
    Jeffrey Levenstone
  • Todd Beabout
    November 22, 2005 at 9:45 pm
    Yes. Sorry.
    -Todd Beabout
    Vazda Studios
  • Dean Sensui
    November 22, 2005 at 11:21 pm
    The only other solution is to capture all your material onto a Firewire drive and hand that over to the production house. This assumes that everyone’s working on the same platform and same software.
    Once the tapes are captured, then you’ll have a copy of a captured material and so will the production house. You can then email one another the much smaller edited program files (with the sequences) and collaborate remotely.
    We do this for our own show and save a heck of a lot of driving and gas.
  • Nick Meyers
    November 24, 2005 at 8:50 pm
    if there are no TC breaks on the tape:
    capture entire tape into one file,
    open in SIMPLE VIDEO OUT
    https://developer.apple.com/samplecode/SimpleVideoOut/SimpleVideoOut.html
    play back to camera with TC set to read EXTERNAL (can you do that with XL1?)
    this app plays video, audio AND TC down the firewire!
    cheers,
    nick
    November 24, 2005 at 10:17 pm
    [NIckM] “play back to camera with TC set to read EXTERNAL (can you do that with XL1?)”
    Nope.
    Nor can you do that with virtually any camcorder.
    That’s why I gave the first answer about needing a deck with “external TC” setting.
    There is no need to dub the tape into FCP and then use “SimpleVideoOut” (which IS a great little app) because:
    Its NOT that there is no timecode going OUT directly from the TAPE playback (there IS, that’s how FCP receives it) its that camcorders don’t “look for it” and instead always just record “fresh” internal TC when they record.
    There may be a few high-end camcorders that have an “external TC” setting, but not many. That’s the province of a deck.
