Making a DVD with 24p HDV footage
Hello all,
I shot some HDV footage at 24p for a project that needs to make it to an SD DVD, and I’m having some trouble with pulldown, interlacing, etc. Here’s my workflow…
1. I edited the piece in FCP with the original HDV 24p sequence settings.
2. I exported an HDV 24p quicktime when I finished
3. I brought that quicktime into compressor to perform pulldown. My settings are 10bit uncompressed SD anamorphic, 29.97fps, dominance set to bottom field, rate conversion set to “fast”, duration at “100% of source”
4. I bring the new 10bit uncompressed quicktime back into compressor for conversion to mpeg-2 for DVD Studio ProWhen I bring the final quicktime into DVD Studio Pro, I get jittering, stuttering, wierd interlacing, etc. Any problem with my workflow? I tried creating a progressive quicktime with better results, but still not as smooth as I would like. Any thoughts?
Dan
