Activity Forums Zaxwerks Making a Cube with Bevels
  • Making a Cube with Bevels
    Posted by Russ Maehl on February 10, 2008 at 6:26 am
    Looking for a setup that will produce a bevel on the edges of all faces of a cube. Need to make the edges of the cube different to that of the cube.
    Russ
    Jon Okerstrom replied 18 years, 6 months ago 2 Members · 1 Reply
  • Jon Okerstrom
    February 10, 2008 at 8:00 pm
    Hi Russ,
    It’s a challenge…
    One way that works – sort of – is to create a square in Illustrator with bevels already cut into the corners. Use the same bevel in the modeler to get bevels next to the faces. You will get bevels on all four sides – even though the intersection won’t be exactly what you expect.
    Jon
