Activity › Forums › Apple Final Cut Pro Legacy › Making a crapier camera look better
Posted by Ian Liuzzi-fedun on January 12, 2008 at 10:25 pmDoes anyone know of a filter(s) or adjustment method to make a crappier camera seem a little more like the other (better) ones used on a multicamera shoot.
Ian Liuzzi-fedun replied 18 years, 8 months ago 7 Members · 9 Replies -
John Pale
January 12, 2008 at 10:33 pmDont expect miracles…but use the FCP 3 way color corrector to get the cameras to match as closely as you can (especially the white balance). Consult FCP Help manual for more info on how to match the cameras.
There’s no magic filter to make a crappy DV camera look like a pro camera, but if the colors match its a lot less distracting.
Ian Liuzzi-fedun
January 12, 2008 at 10:45 pmthat’s what I’ve been doing, just wanted to see if I can do anything more.
Rene Hazekamp
January 12, 2008 at 11:56 pmkill those crappy darlings,
sorry but that’s the only wayrene hazekamp
Walter Biscardi
January 13, 2008 at 12:04 am[Ian Liuzzi-Fedun] “that’s what I’ve been doing, just wanted to see if I can do anything more.”
In addition to what John suggests with the 3-Way, you can also take it into Color and reduce the noise in the blue channel. This can help reduce noise in the image.
But nothing you do will ever get it to “match” the pro cameras. If it’s a completely different shot, take it to black and white and add grain. Call it a “look.”
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow! -
John Davidson
January 13, 2008 at 12:08 amSometimes when confronted with completely awful DV footage, I’ll drop to black and white and bump the contrast up. It’s not the best result but sometimes can make a shot usable as an ‘effecty’ shot.
Hopefully you’re not working with HDV. It tends to fall apart with much correction, much like toilet paper when it gets wet.
Christopher Wright
January 13, 2008 at 5:46 amThat is about the best analogy of the HDV format I have ever heard. And so close to the obvious metaphor.
Jason Porthouse
January 13, 2008 at 11:03 amGraeme Natress’ excellent Chroma Smoother filter can be very effective if you’re integrating DV – it does smooth the image well. I find it’s often DVs handling of colour that gives the game away. Combine this with the 3-way CC and you may find it is a bit more acceptable, IMHO…
Jason
_________________________________
Before you criticise a man, walk a mile in his shoes.
Then when you do criticise him, you’ll be a mile away. And have his shoes.*the artist formally known as Jaymags*
Ian Liuzzi-fedun
January 20, 2008 at 8:19 pmMaybe I could make the other cameras look worse. What would you suggest then?
