Activity Forums Adobe After Effects Expressions Making a compound 3D object w/ Shatter
  • Making a compound 3D object w/ Shatter
    Posted by Darren Gardner on July 25, 2007 at 6:25 am
    I’m trying to make a compound 3D object with the shatter effect and I think I can do it, but I need some help. What I mean by ‘compound’ is – the object has different layers of depth. Its a cog wheel with extruded panels on the front of it. What I’ve done so far is separate each component of the wheel (cogs, body, panels, etc.) and add the shatter effect to each individually. I then ‘pickwhipped’ the shatter camera rotation controls of each to one of the layers. Only problem is, when I rotate the camera the extruded panel layer shifts over the surface of the body layer exposing its 2D nature.
    Is there an expression that would move the panel layer in X and Z space to compensate for the camera’s Y rotation, creating the appearance that the panels are fixed on the surface of the cog wheel body as it rotates?
    Do you see where I’m going with this? Do you know how to do it? Is there a better way? Or am I dreaming?
    Thanks ahead of time.
    Darren Gardner replied 19 years, 1 month ago 2 Members · 3 Replies
  • Filip Vandueren
    July 28, 2007 at 1:29 am
    Very tricky stuff…
    especially since the plugin has it’s own camera system with non standard units: the X and Y is in Pixels, but the Z-distance isn’t.
    I’ll give it a go, but can’t promise results. Think it’s a dead end, but who knows.
    In the mean time take a look at 3D Invigorator: that’s the “real” way of getting interacting 3D objects in your comp. (don’t own it myself though)
  • Filip Vandueren
    Very tricky stuff…
  • Darren Gardner
    July 28, 2007 at 9:34 pm
    Thanks for looking into it. It be great if I could use something like 3D Invigorator, but its not in the budget. I hope you can figure it out. Even something that’s close would help. I understand expressions well enough to modify them, but I can dream up new solutions like some of you can.
    Darren5102
