Activity Forums Maxon Cinema 4D Making a Basket with two colors
  • Making a Basket with two colors
    Posted by Erinn Donnelly on February 27, 2013 at 9:15 pm
    I’m very new to Cinema 4D and I’m trying to make a basket that has one color on the inside of it and a different color on the outside, and for the life of me I can’t figure out how to do it. Thanks for any help!
    Erinn Donnelly replied 13 years, 6 months ago 2 Members · 2 Replies
  • Brian Jones
    February 28, 2013 at 1:32 am
    it depends on whether the basket has thickness, if it does not you can use two textures with the Front or Back setting in the Texture tag. If the basket has thickness then you use two textures but use poygon selections (using the Set Selection command) to control where the textures go
  • Erinn Donnelly
    February 28, 2013 at 10:52 pm
    That did the trick! Thank you so much for your help!
