Activity › Forums › Adobe After Effects › Making a 2D picture into a fake 3D environment
  • Making a 2D picture into a fake 3D environment
    Posted by Laurent Hasson on October 5, 2009 at 9:08 pm
    Hello,
    I have no idea if this can be done or not, and i am not sure if i can explain it correctly, so bear with me please.
    I have a high-res (8mp) picture of a room. The room in real life is a simple squarish room about 16 feet by 20 feet. I took the picture from the entrance with a wall and window in the back, a desk on the right, and a bunk bed on the left. There is some perspective.
    I’d like to add some fake 3D to this so i could in After Effects move a camera around and have the 2D picture be shaped to follow a fake 3D layout.
    Is this possible? Conceptually, i know i can draw lines to give a hint at the perspective. I can also give 3D coordinates to many points throughout the picture which would help my “supposed” 3D software to make my 2D picture a fake 3D picture.
    Thanks for any help,
    Laurent Hasson
    Laurent Hasson replied 16 years, 12 months ago 3 Members · 5 Replies
  • Todd Kopriva
    October 5, 2009 at 9:50 pm
    It sounds like you’re describing a problem that can be solved with the Vanishing Point features in Photoshop and After Effects.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Laurent Hasson
    October 6, 2009 at 12:44 am
    Ah, very cool. “Vanishing point” is the technical term i was looking for. Thanks. I have CS4, and i take it this feature is not incorporated in it? I have to use Photoshop to achieve this then?
  • Todd Kopriva
    October 6, 2009 at 1:41 am
    You prepare the picture in Photoshop and then use the VPE feature to bring the scene into After Effects.
  • Mark Walczak
    October 6, 2009 at 3:19 pm
    Here are some video tuts that may help:
    https://www.videocopilot.net/tutorials/3d_vanishing_point/
    https://www.videocopilot.net/tutorials/3d_camera_projection/
    The second video pertains to image projection, which is another way to do what you are trying to achieve. Personally, I’ve found Vanishing Point to be a little tricky.
    Hope this helps!
    What makes you explode?
    http://www.explosivegraffix.com
  • Laurent Hasson
    October 6, 2009 at 8:13 pm
    Thanks Mark. Looks like 3D projection is more up my alley 🙂 I’ll be trying it tonight.
