Activity Forums Avid Media Composer Making 4:3 footage anamorphic
  • Making 4:3 footage anamorphic
    Posted by Christian Kinnard on September 1, 2005 at 11:19 pm
    I know none of the options are good, but I have to add 4:3 footage in to a sequence with 99% of it anamorphic. Anyone ever do this? What are my best options? Letterbox it (it’s OK if I lose a little picture), squeeze it horizonally, then blow it up?
    Ben Wharton replied 20 years, 11 months ago 3 Members · 3 Replies
  • Michael Phillips
    September 1, 2005 at 11:47 pm
    You want to scale it horizontally. Use the 3D effect.
  • Christian Kinnard
    September 2, 2005 at 12:07 am
    Ahhhh. I knew I was missing something. Thanks!
  • Ben Wharton
    September 17, 2005 at 12:25 am
    Don’t you just use the resize tool and stretch your footage 133%?
    Works for me – although if you have an early version of XPress Pro you’ll see a lovely green line at the tope of the frame after the render.
    However I’ve heard the 3D effect is better quality than resize… Any clarify that?
    Ben
