Activity › Forums › Blackmagic Design › making 3D movie files from SD 4:3 source
  • making 3D movie files from SD 4:3 source
    Posted by Peter Wicks on June 22, 2012 at 4:03 pm
    I’m using BM DL HD 3D Extreme with CS 5.5, and I want to make 3D TV compatible files out of interlaced pal, from twin SD cameras, (not anaglyph or stereoscopic 3D).
    Do I really need to acquire/use an extra thing, like Cineform studio premium or similar; or is there another way.
    I thought with the highly rated gear I’ve got (above), with all their bells and whistles, (and costs), that basic 3D production should be well catered for already, just supply the footage and the monitor. I must be doing something wrong, my other (one eyed) capt – edit – process work turns out fine.
    Can I run my two SD outputs into the PCI express inputs simultaneously to capture together ? ; does Media Express mux ? ; is the BM only 3D extreme after you add some extra thing not previously mentioned ?
    Any clarification or advice or recommendation will be appreciated.
    basicam
    Peter Wicks replied 14 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
