Activity Forums Adobe After Effects Making 3D box
  • Making 3D box
    Posted by Nate Tull on June 13, 2007 at 1:46 pm
    I had a post on here for creating a 3D box and got a couple of responses but one of them sent me a script to use but after effects keeps popping up this when I try to run it…
    ‘Unable to execute script at line 26.After Effects error:Unable to call “addSolid” because of parameter 3. NaN is not an integer.’ https://wemads.com/stuff/3d_cube.zip this is the script. Any other ideas on making a 3D box would be great or any explanation about this script. Thanx so much!
    Nate Tull replied 19 years, 2 months ago 2 Members · 6 Replies
  • Roland R. kahlenberg
    June 13, 2007 at 3:06 pm
    The following thread should sort things out for you –Creating a Box Thread
    HTH
    Roland Kahlenberg
    https://www.broadcastGEMs.com – Adobe After Effects project files
    https://www.myspace.com/rorkrgbspace
  • Nate Tull
    June 13, 2007 at 3:42 pm
    okay it is working…well sorta. when I dup[licate the layer a message comes up saying After Effects warning: Class ‘Layer’ has no property or method named ‘x’ Expression disabled.
    Error occurred at line 41. Comp:’Comp 1′ Layer 7 ….and so on
    The First layer is off to the left when I parent them all to a null the rest of them make the cube. Thanks
    June 13, 2007 at 3:58 pm
    Err, I’m not a computer with AE and I don’t have the script that you’re alluding to. Please re-post with the script if you still need some assistance. I do recall that all of your layers have to be the top six witihn the comop for the Expression to work.
    Cheers
    Roland Kahlenberg
  • Nate Tull
    June 13, 2007 at 4:15 pm
    June 13, 2007 at 4:57 pm
    Dude, you really have to do some work on your own. The following info was in the thread I gave you. Read it. And if it still doesn’t work then re-read the entire thread again until you get it.
    Well you are getting this error because the layers that make the box have to be the topmost layers in the composition. You could place the null below the box layers, and then turn back on the expressions that had the error but I have a better solution:
    1 – Make sure you are working in a square pixel comp
    2 – Apply the expressions to the layers and make the box
    3 – Select All the box layers and press “ee” to bring up all parameters that have expressions applied
    4 – Select these parameters and go to Animation > Keyframe Assistaant > convert expression to keyframes
    5 – Now parent all your layers to a null, add light(s), camera(s) and you are good to go.
    ~Colin
    Cheers
    Roland Kahlenberg
  • Nate Tull
    June 13, 2007 at 5:25 pm
    Thank you so much I cant tell you how much I appreciate this!!!!
