Activity › Forums › AJA Video Systems › making 2hr hdcam deliverables from prores hq – suggestions?
  • making 2hr hdcam deliverables from prores hq – suggestions?
    Posted by Adam Berk on March 7, 2010 at 7:10 pm
    I’ve got some tape deliverables that will need to be made soon for a 2hr program that we’ve conformed in 720p23.98 ProRes HQ. My deliverable formats are 1080i 59.94 HDCAM and 1080 23.98PsF HDCAM-SR. I’ll be running the latest version of Final Cut Studio on an 8-core 2.26ghz nehalem mac with a Kona 3 card. As it sits right now, my final sequence is made up of five nested sequences.
    Are there any specific workflow suggestions that I should follow when trying to make these long form tape deliverables? Should I be ok allowing the Kona to do the format conversion on output? I’ll be pushing the clock on this one so I’m trying to be aware of all possible problem scenarios before I get the decks in here on rental.
    thanks so much,
    adam
    Adam Berk replied 16 years, 6 months ago 5 Members · 18 Replies
  • 18 Replies
  • Shane Ross
    March 8, 2010 at 6:12 pm
    Take your five nested sequences and make your final SINGLE sequence. Make sure that everything meets the network spec in terms of bars/tone, slate, blacks between acts, show timing..everything. Make sure everything is fully rendered. Make sure your audio mapping is right. And yes, let the Kona do the conversion. From 720p 23.98 to 1080psf 23.98, there will be no frame rate conversion, but there will be a cross conversion of 720p to 1080psf. Because of this there will be a frame offset of 1-4 frames. So do small test outputs to figure out what that offset is, and adjust the deck control offset to fix it.
    For the 1080i 29.97, there is TWO convsersions that is happening, and so there might be more of an offset. Let the Kona handle both (make the changes in the Kona CP), and test to figure out what the offset it.
    Shane
  • Joey Burnham
    March 8, 2010 at 7:46 pm
    Not hijacking the thread I don’t think as this is related.
    Shane,
    What to do if the offset isn’t always the same? I’ve been downconverting 1080p 23.98 masterial to NTSC for years and it’s always off by a different number. Eventually I just gave up as the material is for consumer dvd’s and the encoding people don’t really care as they just ingest it anyway.
    Joey
  • Shane Ross
    March 8, 2010 at 7:55 pm
    [Joey Burnham] “What to do if the offset isn’t always the same? I’ve been downconverting 1080p 23.98 masterial to NTSC for years and it’s always off by a different number.”
    You mean, every time you output downconverted, EACH OUTPUT offset is different? I haven’t seen that…not regularly. I might get it 1 in 6 times, but usually I find the offset and that is it for everything that is converted from one format to another.
    Although it is MIGHTY annoying to output an hour or two hour show only to find that your in point is off by 2 frames. A buddy of mine had a trick to detect that before we got far into the output, but I don’t know what it was. Something he did in the machine room.
    Shane
  • Joey Burnham
    March 8, 2010 at 8:00 pm
    It varies generally from output to output. One day it might be four, the next day five…
    This isn’t a big deal to me, been waiting for software / hardware updates to fix it for me. 🙂
  • Adam Berk
    March 8, 2010 at 11:07 pm
    This seems like quite a major issue. Something like this, in my book, would be considered a show stopper bug and be moved to the top of the bug fix priority list. How long have you all been experiencing this? I’m entirely new to the world of final cut pro and kona-> we’re a finishing house with flame and smoke. I understand that this is probably a limitation of the kona hardware but having the offset change randomly is what scares me. If the offset changes, any workflow or software compensation methods would be rendered futile. After hearing about this, I’ll just plan to do the format conversions with shake or quicktime before I output.
    Thanks so much for informing me of this frame offset thing. It’s exactly the type of info I was looking out for. The cow rocks.
    -ab
  • Joey Burnham
    March 8, 2010 at 11:12 pm
    I just want to be on the record trying not to influence your decision. If you have a Flame and Smoke system at the ready then by all means. This isn’t necessarily a problem for everyone. System configuration and setup vary from place to place and I know plenty of people where this isn’t an issue.
    Best,
    Joey
  • Adam Berk
    March 8, 2010 at 11:25 pm
    Good to know. Hopefully I won’t have any problems with it. We’re just finishing up this job, which is our first using FCP and Color as the finishing platform. There have certainly been some snags, but it I’ve been pretty happy with it overall. I wouldn’t feel comfortable using this platform with some of our commercial clients, but for independent feature finishing (a market we’d like to be more involved in), it seems like a great setup. I’ll be excited for the next software update, and another opportunity to use it. If we could only get audio playback, better re-conform abilities, Color integrated tape i/o, realtime playback of rendered material, and faster rendering, I’d feel much more confident in using the system for spots as well.
    Again, thanks so much for the advice thus far!
    -ab
  • Joey Burnham
    March 8, 2010 at 11:41 pm
    Well, FCP doesn’t cost 6 figures, so not really comparing apples to apples.
    [Adam Berk] “If we could only get audio playback”
    Um, why not? This sounds like a setup problem.
    [Adam Berk] “better re-conform abilities”
    Not gonna happen any time soon.
    [Adam Berk] “Color integrated tape i/o”
    Not sure what you mean but I assume color timing on ingest???
    [Adam Berk] “realtime playback of rendered material”
    This shouldn’t be a problem. As long as your sequence settings match your video, no rendering should be needed. Choose the easy setup that exactly matches your material.
    Best,
    Joey
  • Adam Berk
    March 8, 2010 at 11:59 pm
    Sorry, should have been more specific. My comments mainly referred to Color, not FCP.
    [Joey Burnham] “Um, why not? This sounds like a setup problem.”
    Was referring to Color…
    [Joey Burnham] Not gonna happen any time soon.
    Was referring to Color’s dependence on shot number/order to re-conform a changed edit. You can change your edit, just don’t change the number or order of the shots…(please correct me here if I’m wrong)
    [Joey Burnham] Not sure what you mean but I assume color timing on ingest???
    No, what I mean here is that I’d like to be able to conform from tape right inside Color, instead of having to use FCP. I’d also like to be able to layoff to tape right from inside Color… either Insert or Assemble with source timecodes (like a re-transfer of selects).
    [Joey Burnham]This shouldn’t be a problem. As long as your sequence settings match your video, no rendering should be needed. Choose the easy setup that exactly matches your material.
    Again, was referring to Color. Not having any realtime issues with FCP. Having to take a sequence back into FCP each time the client would like to see realtime playback with audio would be a major show stopper for us with most clients.
    But again, don’t get me wrong. I’ve been enjoying working on this setup. Very much so, it’s just not entirely appropriate for the majority of our work, which is really just too bad. I’m just hoping that Apple can up their game a bit and revert some of their attention back to all of us is the professional media and entertainment business. Yes, we all love our ipods, but we need the great tools we need in order to buy more for our friends and fams!
    I apologize in advance for this digression of a thread.
    thanks again,
    ab
  • Adam Berk
    March 9, 2010 at 12:23 am
    [Joey Burnham] Well, FCP doesn’t cost 6 figures, so not really comparing apples to apples.
    And the thing with comparing FCS to something like Smoke is that cost should not be considered when deciding “which of these two systems will help me do the best work I can, for the clients I have, in the environment that I work in?” The cost consideration comes after that.
    I just don’t think that if we invited Steve Jobs to a town-hall meeting with finishing artists and colorists, and said to him, “Apple’s tools are great for the price, but when it comes to having an elegantly designed finishing system with great tools, speed and ultimate reliability….well, you get what you pay for!” that he or anyone else involved in the development of FCS at Apple would be satisfied. People take pride in their work. People, in general, care about doing well at what they do. And what Apple claims to be doing is developing a software platform that can be used up to the highest scale of work….. national advertising, high profile feature film, etc. Look at their promo materials. Based on what Apple promotes FCS to be, I don’t see why we shouldn’t be comparing Color to Lustre, Resolve, Pablo, Speedgrade, Smoke, etc.
    When we bid on a lower budget project and win, we don’t say to ourselves that we’re not going to do our best work. We may limit the scale of work to what the client can afford, but by no means do we give lower quality output. I don’t see why software developers working at Apple, or Autodesk or Avid or anywhere else would think any differently.
