Activity › Forums › VEGAS Pro › Making 24P DVD with DVDA
  • Making 24P DVD with DVDA
    Posted by Kert on July 2, 2007 at 4:50 am
    I tried and searched the past posts for how to make 24P DVDs with DVDA.
    No luck. There is some info out there but so far I have not been able to make a 24P dvd.
    Would someone write down the exact steps (I mean exact) needed to get from a 60i DV (on the time line) to 24P DVD?
    I would really appriciate it.
    John Kert
    Mike Kujbida replied 19 years, 3 months ago 2 Members · 1 Reply
  • Mike Kujbida
    July 2, 2007 at 9:24 am
    You need to render out a 24p file from Vegas and feed that to DVDA.
    From the DVDA help file:
    If you’re using the MainConcept MPEG-2 encoder in Vegas software, use the DVD Architect NTSC video stream or DVD Architect 24p NTSC video stream template to render your video stream (you’ll need to render your audio stream separately according to the parameters listed in the AC-3 audio or PCM audio headings).
