Activity › Forums › Apple Final Cut Pro Legacy › makeing a m2v and ac3 file
Posted by Kelly Laudien on August 24, 2010 at 3:16 pmHow do you make a m2v as well as the audio ac3 files in fcp pro so I can burn a dvd in imovie, when I export file to compressor there a lot of settings but I do not see m2v. ps how would you make a dvd from fcp.
John Fishback replied 12 years, 2 months ago 3 Members · 7 Replies -
John Fishback
August 24, 2010 at 8:04 pmmv2 is shorthand for mpeg-2. Export a QT Using Current Settings. Do not use QT Conversion. Use that file in Compressor. Apply the appropriate settings from Apple > DVD > Best Quality dependent on program length. Be sure to change the parameters in the ac3 setting as follows: in the Inspector > Encoder > Audio tab change Dialog Normalization from -27 to -31 and in the Preprocessing tab > change the Compression Preset to None. I’m not familiar with iDVD. I suggest you learn DVDSP. Read about it in the DVDSP Cow forum. It’s not hard to learn.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Kelly Laudien
August 25, 2010 at 12:22 amso are saying I shouldn’t use compressor just export as per your settings.
Thanks Kelly
John Fishback
August 25, 2010 at 2:16 pmDon’t use Send to Compressor or Quicktime Conversion. It’s a 2-step process. First export a Quicktime from your timeline Using Current Settings. Then use that exported file in Compressor to encode the mv2 and ac3 files.
John
Bryan Michael stoller
July 23, 2014 at 1:27 amSo to clarify. I make a qt with current settings of my movie even if that’s 200 gigs. Then I put it into compressor. How do I attach a separate AC3 5.1 audio file? I tried that before in compressor and it didn’t have an option to marry the audio file to the video file. I also tried this in Toast which did ask me for an audio file to compliment the M2V file when it recognized it as not having audio. This worked, but I was only able to generate a 3.5 gig M2v file using compressor and not a larger M2v file to better suite the higher quality of Blu Ray. Help!!!
John Fishback
July 23, 2014 at 2:00 amCompressor makes the mv2 and the ac3 files. You use an authoring program like DVD Studio Pro to marry the 2 together to produce the DVD. You’ll find more info on the DVDSP forum.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.9.2, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCP-X 10.1.1, Motion 5.0.7, Compressor 4.0.7
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
July 23, 2014 at 2:18 amThanks John! I didn’t realize DVD Studio Pro could make Blu-Rays. If that’s the case it’s easy as that’s how I make my regular DVD’s with separate audio.
John Fishback
July 23, 2014 at 12:20 pmSorry, I missed you wanted to make a Blu Ray. Unfortunately, DVDSP won’t work for that. However, once you have the mv2 & ac3 from Compressor I believe Toast with its Blu Ray plugin will make the disc. I’ve never been asked for a Blu Ray so I’m not an expert on that. I’ve read a lot of posts about it on the COW over the years so a search should get you more info. Walter Biscardi posted a lot about making Blu Rays.
John
