Activity Forums Adobe After Effects Make water look like black ink….Low Key?
  • Make water look like black ink….Low Key?
    Posted by Kevin Obrien on April 9, 2013 at 3:06 am
    Hello All…
    I’d like to make some footage of flowing water look black as ink with reflected highlights (as in a Low Key black & white photo) I have no idea if this is possible in After Effects…
    ideas anyone?
    Kevin Obrien replied 13 years, 5 months ago 2 Members · 4 Replies
  • John Cuevas
    April 9, 2013 at 11:37 am
    Try using a levels or curves effect and take most of the color, but leave the highlights. Here’s a quick example project I did, to show you what I mean.
    5804_inkfolder.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Kevin Obrien
    April 9, 2013 at 2:56 pm
    Thanks for the reply John… I have CS5… can’t open the file you sent. Do you have a CS5 version by chance?
  • John Cuevas
    April 9, 2013 at 3:17 pm
    FYI, this was a quick effort on my part, BTW so you would probably want to adjust the masks/effects more than I did…but here’s a CS5 version of the project-just relink to the already downloaded picture and you should be good to go.
    5805_inkcs5.aep.zip
    BTW, you can download a trial version of CS5.5(and 6 from Adobe’s sight). https://prodesigntools.com/adobe-cs5-5-direct-download-links.html
    Thinkck.com
  • Kevin Obrien
    April 9, 2013 at 8:01 pm
    Thanks John for your help (again!) I really appreciate your input…
    Cheers1
    Kevin
